I purchased xperia T3 on 25/01/2015.
From starting it has heating problem even that during vedio recording it auto shut dowm camera within 2-5 minutes in HD mode.
When i contact to service center for repare they charge mother of mobile but this proble is as it is.
Naw can you provide me information about the vedio recording limitaion of xperia T3 and at which temperature i should use this mobile.
Sohan
what if you reinstall the latest update with PCC
Bridge (for Mac)
Same problem I M Facing tooo
have u ask the service center to replace ur hand set? if not then u can do that.
This, heating problem, is not in this model. Mostly Xperia model have this problem.
So guy go for other brand.
Sony fail to maintane it's brand quality.
Hi I am facing same problem, consumer forum , what do you mean exactly?
make a notice ans send it to sony and mentioned your problem and what u want either change of hand set or refund ur billing amount.
They will reply to u and solve ur problem and provide solution by replacing ur hand set.
If they don't do so. you can file a case in consumer fourm against sony and ask your complete refund and expensise made by to file the case and for documentation and for lawyer(lawyer is not compulsory to hire) or u can introduce ur case by ur self
