Xperia T2 Ultra / T2 Ultra Dual Lollipop issues and feedback
This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
213 REPLIES 213
amit_rocking87
cool .
any improvements after update?
Ah4u
Kitkat better than lollipop for T2, how can i get kitkat again? Anyone answer please.
Nishant5788
Phone is not hanging much after 5.1.1. I have already disabled useless google apps to increase performance but now it looks much faster.
Tags (1)
iamashh1991
i am facing the similar issue with my xperia T2 ultra... everytime i have to listen to the music or received or make any phone call, or watch videos, my phone speakers won't work. i have to plugin in a earphone or headphone to listen the sound... it is happening since i have updated my phone to lollipop... any help????????
@Tomacq wrote:
I found the the loudspeaker of T2 Ultra Dual outputs crackling sound,while playing music and during notifications.it occurred after the Lollipop update.
Tags (1)
pawan12
On lolipop, when i try toh call any one, its too late response to select sim card, how toh problem fixed
Abigail_Marie
What happen to the front camera of my T2 Ultra, after the update it turned out to be greeny and blurry. It's like the front camera is only VGA, kindly fix this Sony. I know other T2 Ultra users that has the same problem.
Prashant61
Recently I found an issue in my phone SONY XPERIA T2 ULTRA DUAL, Android
version 5.1.1 after installing WhatsApp.
When I install WhatsApp my Google contacts turns to local contacts and when
I try to add new contacts I only get option to add contacts locally.
Option to select Google account is disabled. Also filters for syncing
Google contacts is disappeared.
If I uninstall the WhatsApp application again the contact options comes to
normal.
Please suggest solution.
Regards,
Prashant
shivam212
Plz help me i have sound crackling issue after update:-SS
amirmasoodsh
Hi , when i update , my phone dont read SIM and I see Invalid Card, i DownGrade to android 4.3, 4.4.2 , 4.4.3 & 5.0.2 & ..... but dount work my antenna phone and i see Invalid Card..........
NicksInLine
The same thing happened to me. The speaker stopped working after plugging the headset. But when on headset it works. And when calling only the loudspeaker works. And alarms work too. But music doesn't
