This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
Lollipop supports screen recording but there's no preinstalled app for it in T2 Ultra. You can however download apps for it from Google Play. Search for "lollipop screen recorder" or similar. I tested a few and it works fine.
I'll see if i can find some information about HDR.
Regarding RAM, i believe the management of memory is standard for Android.
I think..RAM management is working fine for me..no lag (in kitkat or lollipop firmware)
Okay then., I just thought there's a screen record
cause at Z2 lollipop they got that screen record at the power menu.
no problem though, no root needed to do that now, can just install some few MB apps to do that
sure., glad if somehow we can point out few bugs or thing that sony forgot to check.
and at lollipop there's few missing widget compared from kitkat, also the clock is not resizable anymore by the way.
Thanks anyway Rickard.
the new lollipop update is a mess and it has degraded the quality of my sony mobile
I am hoping that it might be fixed.
Try performing a system repair using PC Companion as this will often fix issues - This will factory reset your phone and erase all data so best to backup before you begin
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
3. Manual Brightness adjustment not possible. It is set to Automatic after lollipop update. i found it is very difficult to use.
4. Battery draining very fast, atleat 50% less use after update.
5. Unnecessarily menu icon size has increased, which not look good at all.
6. Switching SIM card for data tarrif is taking lon time. Switching and switching and switching
Come on Sony resolve this problems.
