Xperia T2 Ultra / T2 Ultra Dual Lollipop issues and feedback
This thread is for T2 Ultra users to report any bugs after lollipop, before you do so, try the following:
If your battery drain faster or the phone seems slower or apps are crashing, it'll be wise to reinstall lollipop with PCC
even better if you update deleting all the apps and settings, keep in mind that by doing so, you can not use the backup & restore app to restore anything.
PC Companion (PCC)
Bridge (for Mac)
This thread it's not to ask when is the update going to be released in your country and/or carrier network. you can read about it here
http://talk.sonymobile.com/t5/Software-Updates/Android-5-0-When-are-we-getting-Lollipop-Which-Xperia...
213 REPLIES 213
rizqiangga
I already upgrade my xperia t2 ultra single sim with lollipop. on kitkat i always playing hd game like real racing 3, modern combat 5, etc. but when i try play that game on lollipop, all hd game always experiencing heavy lag. i already try re format my xperia and installing that game again and still lag....
renownep
I found that on recent apps the favourite bar of small apps is always missing. Every time i add small apps to favourite bar in a matter of time it clears itself with no reason.
s4alon
Is it just me or the auto brightness setting is no longer available ?
--------EDIT------------------
it's no longer available but the auto brightness is working.
so no way to disable it for sure
and the most noticeable bugs is at the front camera i guess
the noise amount is worsening and the result is always a bit darker.
hope it's noted Slightly_smiling_Face
and I don't really know where should I report this to, but before update at kitkat the google camera got the panorama, sphere, and defocus feature.
after update that feature disappear. the only left is camera, and video.
from what I know at toying with other phone and ROM this might be OS related maybe.
the google camera didn't recognize the capability of the hardware.
Thanks for the update anyways., great performance
Nishant5788
New bug...I am on low battery mode...it should disable mobile data but it was still working..Screenshot_2015-04-26-20-55-59.png
Megharaj
Still videocall on network is not available 😞
Dude there is new option include that is the settings for automatic brightness 🔆 on or off [adoptive Brightness ]
s4alon
Oh yes., there that in setting., but the quick toogle one is missing.
The one which ussually under the brightness slider.
Btw did anyone having this issue at the recent apps window ?
Is that normal or what ?
I don't really know.
I installed the rom fresh.
No backup remain from Kitkat
profile.country.RO.title
_alexdon_
I am not sure why you get that but lollipop doesn't have widgets as KK used to.
alexdon
p3rci
1. Cracking sound with Audio output
2. Large Icons
3. Clogged up all open apps area (older one preferred)
4. Simple silent mode not available.
5. Extra swipe i.e swipe and then enter pattern. Earlier it as simply enter the pattern.
It would be nice if the smoothness of 4.4.3 is retained.
s4alon
1 more guys
I think this is a bit un proportional.
Also the image picker for web doesn't show overview at thumbnail.
At KK it does.
Hope this'll help to sort the bug, and missed part.
bj8
Hi
I am facing a big problem with xperia t2 ultra dual phone because of updating the lolipop.applications are opening slowly and phone also slow.Pls help me or give me a
suggestion
Regards
