This is what I do
open the file commander app (download one if you don't have one) > internal storage > Whatsapp > copy > SD card > paste it > it might take a while > every now and then cut paste the following
Internal storage > whatsapp > media > open the following folders
Whatsapp Audio
Whatsapp images
Whatsapp Video
Select all the content > SD cards > Whatsapp > media > look for the correct folder > paste it
that's only if you want to keep those files if not just clear the data every week or so
Indeed, you don't have much space left, if you have whatsapp or facebook or instagram or pandora/spotify then
settings > apps > all > look for the apps > clear data > repeat as need it
This is what I do
Whatsapp Audio
Whatsapp images
Whatsapp Video
Anytime
