Hello guys.
I recently had a problem with my smartphone xperia sp...
I can't hear sounds from the speaker.I tried walkman - games but no sound.
I tried to reset my phone with Factory Reset and PC Companion.
What can I do now :/?
I will appreciate any help
I don't have an answer for that, but my opinion is that it should be under warranty as long as there isn't water damage or other damage, but do contact them
Repair your phone with SUS or PCC, if that doesn't work then take it to a Sony repair center
Bridge (for Mac)
Will they replace the phone by taking any money or they will fix it free?
(dumb question but you never know)
