Just to let you know i am new to sony and my phone.
When i take pictures with my phone and zoom in it gets blury and fuzzy why? any tips you can give me?
Yes,if you need optical zoom,just go for the qx10 lens from sony.
http://www.sony.co.uk/product/dsc-qx-series/dsc-qx10/compatible-products
If you zoom it to maximum,of course it will get a little blurry,you need a still hand to take those shots.Those which you see are pixels.
I have heard of this problem before, it is good for shot distance but not for long, is there anything you can suggest to make it slightly better?
I might invest in that but for now i will stick with it. luckly i have got a good camrea so i can use that for going on holiday etc.
Of course,it is great(exmor rs,8mpx).Check this out:
http://forum.xda-developers.com/showthread.php?t=2516680
