while updating process using Sony PC Companion at step 3 (update) it takes so long time and the loading bar dosen't move from about 1 hour till now, so kindly recommend what should I do ??
Try using SEUS or SUS found here
Once installed select your phone and follow the onscreen instructions
@thommo, thanks for your answer. but I'll keep the updating window up or abort it and try again after downloading the update you gave me ??
Stop the PCC and use SUS.
