Xperia S touchscreen not responding
GeoffO
My Xperia S got wet and now the touchscreen doesnt respond to touch even though everything else works (screen display, power button, alarm sounds etc).
Is there anything I can do to get it working again?
Tags (2)
Samuel1
Hero
I'm sorry to hear that.
I suggest that you raise this with your local support team to send in the phone to a service center for repair.
Local support.
3 REPLIES 3
Samuel1
Hero
Local support.
GeoffO
Ok. I was afraid you might say that!
The phone is over 3 years old so probably not worth me repairing
Thanks for your prompt reply.
@GeoffO
You could DIY, buy the LCD/Digitizer on ebay or amazon or somewhere and replace it yourself, it's not that complicated
http://www.xperiablog.net/2012/04/30/xperia-s-disassembly-guide/
