Good afternoon,
I have a problem with the phone, the Xperia phone working properly but the battery label shows that the phone is charging but the phone is not connected to the charger and steadily so.
When the phone is switched off and plug the charger it displays that charges the battery when you disconnect charger battery phone gives normal picture batteries but begins turned on the light indication and is sore.
Tx
Force restart(power button+vol up until the phone vibrates).See if the glitches go on after this.
Done several times but without result:smileysad:
Maybe your Xperia founded perpetual energy source...
jk
I sometimes have the opposite bug... I plug my Xperia and verify that the icon says charging, but after a while is shows a decrease of charge even when I am not using the phone at all.
In normal circumstances, you should not be doing this but because it may be a connector issue, you can try this. Unscrew all screws on the back panel, slowly lift up the panel near the light bar, you should be able to remove the battery and put it back. Restart and see whether the issue is resolved.
hello tx I removed the battery and back but still the same
