Xperia S not able to boot
santerrific
Recently Unlocked bootloader officially from sony mobile website
later on rooted it from xda
installed custom recovery mode through FASTBOOT MODE
after installing it led me to recovery mode
i backed up my data
then i selected REBOOT SYSTEM NOW
but its again rebooting to recovery mode
not going beyond that !
how do i get over it ?
30 REPLIES 30
santerrific
i have not used flashtool
santerrific
version :
ICS
2.45
Thommo
Download this https://docs.google.com/open?id=0B-yM_qnM8ZPRNWU5R0tnblhUYkk  and stick it in your Fastboot folder on C: Drive then open a command prompt and type fastboot flash boot kernel.sin then hit enter and connect your phone in fastboot mode
Thommo
Takes seconds to complete - Once done your phone should reboot if not then you may have to use Flashtools or the new Sony repair program
santerrific
it showed as finished ! but nothing further !
Thommo
Have you tried to start your phone - You may have to hold the vol up and power as mentioned before
santerrific
Awesome ! thank you Slightly_smiling_Face
Thommo
No bother - But if you could mark any of answers as correct or helpful if you feel I have been
Edit - I see you have
santerrific
the phone is still rooted
How do i enter into recovery mode  without being stuck agin  and install custom roms ?
Thommo
Recovery mode is a separate file which you need to flash using fastboot the proper file to use is the nozomi file found on my drive here https://docs.google.com/open?id=0B-yM_qnM8ZPRU2VWazlla19tWE0
To use as you just did with the kernal.sin you need to copy it to your fastboot folder and type in
fastboot flash boot recovery-nozomi.img then your phone will boot into recovery then to fix that re-flash the kernal.sin
