I have an issue with the LCD, it does lits and the touch is working, but the screen is totally black, I reflashed it with several firmware versions, still no change, I went to serveral repair shops, some says its the LCD screen and some says its the Flat Cable, I am lost, if someone faced the same issue, please let me know.
Regards.
You have 2 options
1) buy the parts yourself and repair it yourself, it will be a lot cheaper
or
2) go for the cheapest option, if its the cable replace the cable
You won't be able to find out until you or someone open up your phone
One if the shops opened it and they said its the screen, but I'm not comfortable with this diagnose.
Thanks.
This is how to take it apart
http://www.xperiablog.net/2012/04/30/xperia-s-disassembly-guide/
and you can buy the parts on Ebay
Don't forget to give Kudos
Thanks for your suggestion, could you recommend a site for buying the items.
Regards.
Ebay its a great place to buy them as if the units are faulty you can get your money back.
