XPERIA S is getting Slow and Slow everyday
srsnth
Hi,  I have SOny Xperia S. And is running on ICS. Its working very very slow.
For ex: If i get an sms during the screen lock. If a slide on the SMS the whole messgae box will appear as blank. If i come back and and if we open it again, it will show the messages. Message box size is also very low(at Max 10 sms are there).
Can any one suggest how to speed it up...
one more query is when we are getting jelly bean for sony xperia s.
13 REPLIES 13
Djallencruz
yes i do. wha other suggestions can you give me?
it will be better if  u show me the screenshot of ur Running apps .. and the apps u have installed
FirozDevgn
Best to change yur phone
Kacperovsky01
From where did you get your xperia? The used ones on ebay/amazon are the ones that run like a 10$ click phone with forced touch option.
The ones from aliexpress are reconstructed and recovered with cheaper parts if something is broken and have a risk of having chinese system (wostore instead of google and at least 20 useless apps) edit: the ultra cheap ones from aliexpress are these recovered ones*
