xperia p sms tone problem
s9
I am using xperia p & jelly bean last 6 months without any problem. But now I m facing a problem.i don't always get the sms notification tone (fb notification is ok).though other tone & vibration is still working. I check the setting & it is ok. So I restore the setting. Then I notice that everything is ok but after 2days the problem is again noticed.what can I do now??
15 REPLIES 15
s9
no.I use only facebook & fb massenger. both are always up to date. Above all post is mine. so give an advice as soon as poasible based on previous info.
profile.country.RO.title
_alexdon_
Have you tried the last solution with turning the default notification to silent?I think you should repair phone software with SUS,you have a better chance of it working after.
alexdon
s9
Yes I tried. And it worked for few days. Now it doesn't work. I only get the vibrate notifiaction. I m using the latest version 4.1.2 build number 6.2.A.1.100. That means I have to reinstal the JB?? Is there any way to repair using wifi connection in phone? That means without using SUS.
_alexdon_
Nope,the best way to repair is using SUS or PCC.But SUS is recommended.
alexdon
thzimme43
I wished people would not allways use abbreviations. What is SUS or PCC?? a bit more effort to spell out things would really help beginners too.
_alexdon_
