Xperia extremely slow....
Rayday
My Xperia sp was stupendous before I updated to 4.3, it was fast and smooth and never froze. Now, it just keeps freezing at everything I do! It takes ages opening every app andI have to keep emergency shutting down!
Here's what I have tried:
Getting a 32gb sd card and moving as much data as possible to it (I couldn't move the apps)
Disabling Google Chrome
Removing the cache of my apps
Is there anything else that could possibly help? And why is it so slow on 4.3?
profile.country.RO.title
_alexdon_
4.3 needs more RAM than previous versions.You should restart the phone regularly.Maybe try a software repair.
alexdon
16 REPLIES 16
_alexdon_
alexdon
Rayday
Oh. Is there anyway to downgrade to 4.1.2? Please tell me there is.
_alexdon_
http://forum.xda-developers.com/showthread.php?t=2658952
See here.But be careful that it might void warranty.
alexdon
Rayday
Thanks man. But are you sure this is safe for my phone?
_alexdon_
What have I told you?Read more here and see if it is worth it.I told you it might void warranty.
alexdon
MałaMi
I have the same problem with my phone. Can anyone tell me what's the point of releasing an update for a phone with this amount of RAM which need it so much that this practically makes my phone useless? Does the people who done this, didn't even check this or what?!?!?!?
blackbox
I think the Android community in general needs to come up with better testing methods. Sony are not the only ones to release dodgy updates. It's not doing the platform's reputation any good.
Ridgeback
I am really disgusted with this. To release an update that will turn good phones into useless bricks is worse than foolish. I really want to revert to the old version of OS, but I cannot do that if it means invalidating the warranty. What should I do?
GreekXperiaSp
http://talk.sonymobile.com/t5/Xperia-Z-ZL-ZR/How-to-manually-update-downgrade-root-2013-Xperias/m-p/... is a guide to downgrade ur xperia..it voids though the warranty...so its up to you what you will do...i suggest you to wait for another update that will probably fix the bugs in Sp...But no one knows if its in sony plans to roll out a new update and when..
