xloud problem in xperia p after 4.1
didar
Xloud problem in xperia p after upgrade, when I am xloud on speaker volume very bad when xloud off volume good plz fix it
Tags (1)
profile.country.RO.title
_alexdon_
Probably you need a repair of the software,followed by a factory settings reset.
alexdon
4 REPLIES 4
_alexdon_
alexdon
didar
Factory reset ,software reinstall , but problem is still
hosseindj
you must change youre phone bro :smileysmileywink:
Tusharrrrrr
i'm also facing the same problem...so i turned xloud off
