WIFI NOT WORK -
ebrahimirani
WIFI NOT WORK -
hi
i have xperia s
update to 4.04
after update wifi is working but after once restart my wifi dosent work any way
could you please help mee
delwoods
Have you tried a soft reset ?
If not then press and hold volume up and the power button together, wait for your phone to viabrate 3 times and then it will turn off, now restart your phone and see if the problem is still there.
5 REPLIES 5
delwoods
ebrahimirani
tnx a lot
its working
delwoods
Glad I could help Winking_Face
Norris
Hi, i have same problem with the WIFI, can´t move the button to Wifi, i have turned the phone many times but still doesn´t work.
what is the problem with the WIFI ??
Haven´t work for a long time and its very enoying
Regards Lena
profile.country.RO.title
_alexdon_
Have you tried force restart?(power button+vol up until the phone restarts).Also,can you turn on wifi from the widget directly?
alexdon
