WIFI Automatically on
Whenever i turnned of the Internet connect. the WIFI automatically turn on
Nabeel
Master
4 REPLIES 4
jatinrungta
Enthusiast
May be you have installed Juice Defender or something else just check the internet policy of your phone.SOme app also may have been done some conflict or they require some special permission.You may have included some apps as the phone administrator that is automatically activating the net
Nabeel
Master
It could be due to third party app interfering
Check apps such as antivirus, task killers ( same types ) and revise their settings
Explore these threads of similar type
  3G Data traffic keeps switching back on
     My Xperia X8 display light automatically turns on, even if not in use
     XPERIA S, wifi auto switch-on
     Display keeps turning on.
    Fail to Save Default Actions
     Screen Blinks every 10 secs after locking in Xperia Neo V
     Display keep turning on/off automatically
     Live with Walkman screen turns on suddenly
RuiCarvalho
Please pay attention to these problems:
http://talk.sonymobile.com/thread/55321
http://talk.sonymobile.com/message/350786#350786
http://talk.sonymobile.com/message/350738#350738
http://talk.sonymobile.com/message/223550#223550
(there may be more posts)
They all refer to the same issue!! Still with NO solution. And is being given little attention by SONY!
<<< Wi-fi won't turn off and stops working even though it's "on" >>>
ghencea-RO
Aside from that, I would recommand that wifi sleep policy when screen is off to have less than 15 min timer. During a day we use the phone for one reason or another within 15 min interval  so the option doesn't help with anything. Only during the night maybe. I guess turning the wifi off as the screen is closed will do better. That suggestion is for the new models Xperia U being obsolete already.
