Could you elaborate?
Do you have get an error?
Try to clear data for voice recorder in settings-apps-all,force stop and restart the phone.
Waiting for your answer.
You are welcome,my friend.
No problem,I can unmark the solution if needed,but let it that way,it is just for people to see.
