Hello, i want to update my system but i dont have usb cable, is there anyway to update without it? Like via ftp ?
You cannot,you need a USB cable for any action that requires computer.
Only OTA (over the air) but there must be the update available like that.
Where i can find that? My phone is x10 mini
It will come to you if available.What firmware do you have now? 2.3.3 is last I guess.
i have 1.6, but when i try to update it says that i have to do it from computer via sony pc companion, but this software need's usb cable connection, which i dont have
Sorry for my bad english btw.
It means computer required then.Can't you get to a computer?
I'm in a computer, but i dont have the usb cable, to connect it to my phone
Ask someone to borrow you one.
I was expecting a aswner to my question, there is any other way to update it? like via ftp or something?
