My Xperia Arc S is locked by my provider.
I would like to unlock it to use it with another provider.
Could you provide me the unlock code ?
IMEI : [removed by moderator]
Thanks in advance
I don't have this code i'm afraid, you need to get it from the operator.
Have you tried to enter any random codes? You only have 5 attempts to enter the correct code so if you have entered wrong code too many times it can't be unlocked.
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
To get an unlock code for your phone you need to contact the operator the phone is locked to.
Hi Richard,
Thanks for your quick reply.
I've try to unlock it with my operator. But it doesn't work
That's why it try to ask you
I've never enter any code.
I'm waiting for the good code
Thank you again
I'll re-contact my operator
