Touchscreen does not response in random places.
Deadmask
Hallo everyone, recently I'm having a issue of non resopnsive touchscreen.Sometimes the touchscreen dosen't respond to touch or sweeps. It happens in different parts of the screen at different times.
As you can see the non-responsive section keeps changing everytime. But at lest one section will always remain unresponsive.
It's really annoyng while typing anything on the virtual keyboard as lot of taps are ignored.
I tried factory reset but that did not solve the problem then I tried to reinstall the firmware using SUS but that also didn't change anything
I'm currently on ICS. The problem started a few weeks after updating to ICS.
The phone is Unrooted stock. I also don't want to flash any firmware (Don't want to lose my warrenty)
Is this a hardware problem? Should I take it to the service centre? If it's a hardware problem why the non responsive section keeps changing?
13 REPLIES 13
sbhandepatil
m to havin same problem wd ma XPU...wt m i supposed to do???
dragpyre
Like has already been said in this thread, take it to a Sony Repair Centre. They will replace the panel.
wikki131
i have the problem in my Xperia U which is similar like this but i can able to make straight line easily no lacking in between .but some time it's not response and  i m totally unable to draw and then able to draw after that i touch the screen not only these also the lower touch button have the same problem what can i do there is a hardware problem or software ??? my phone is not updated to ics yet firmware version is 6.0.b.3.188 help me please..........
arnav3107
facing the same problem like u wikki131 ...
please let me know how did u fix it...thanks
