T2 Ultra not booting after installing Lollipop.
Reventon
My T2 Ultra Dual was the finest phone I've seen until I received a message to update to Lollipop.
I did, and now it is not even booting.
I tried hard resetting but nothing happens.
Does anyone know how to format it ?
22 REPLIES 22
Reventon
again...
xyz..android-hilfe.de/attachments/sony-xperia-z3-compact-forum/338556d1413055665-firmware-update-fehlgeschlagen-z3c-startet-nicht-mehr-img_3554.jpg
xyz = www
@Reventon
the link on your last post doesn't work
Reventon
replace  "xyz"  by  "www"
@Reventon
I've seen the pictures, just start the update all over again.
Reventon
I can't.
PCC does not recognized the phone.
Do you know how to format it ?
@Reventon
Press and hold power & volume up for few seconds, does it turn off? if its off then start the update process.
Reventon
Yes it turns off.
But when I press On to start the phone it goes to this screen.
Right now, it is charging...
But I think it will not work.
I need to format it.
Reventon
And I can't get it done in a authorized assistance, because here in Brazil they will freaking steal my private data. You don't know how crazy it is here in Brazil.
The sh*t is that not even PCC is recognizing the phone.
@Reventon
turn off the phone > charge it > run PCC > run all the steps to repair the phone > the phone should remain off > once you are asked to connect the phone do so, again, the phone must be off.
Reventon
I did everything, but when I'm asked to connect the phone, I did, but PCC does not recognizes my phone.
