Swiching Apps with home button
HelloSony
Hi there
Before the latest update, one would get the possibility to switch between recent/open apps when pressing the home button for a bit longer. Now this action only brings up the google search function. Is there any other way the switching-option is accessible now after the update?
thanks for your help
profile.country.RO.title
_alexdon_
For the task manager you need to double tap home button.
alexdon
5 REPLIES 5
_alexdon_
alexdon
HelloSony
ah wow, could have tried that Flushed_Face
thank you
_alexdon_
That's ok my friend,do not forget to give kudos.
alexdon
jayzee
The home button is anyways so unresponsive, trying to double tap is a lot of effort.
_alexdon_
It is the only way...
alexdon
