I'm Suffering from screen touch while charging? It doesn't response correctly at all, Plz help
what I can do??
1. Try a different cable.
2. Use a different wall socket as usually this occurs when incorrect voltage enters the device.
Thanks alot for advice.
Keep us updated.
