status Bar power switch symbol
guy_c
Hello
Is there an exhaustive list of these symbols? And particularly, what doers the circle with vertical Bar mean?
thanks for your time
6 REPLIES 6
Jake-SonyXperia
Champion
Hi G2c,
Welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I am not sure what the Circle with the vertical bar is and it does not seem to be the in symbols listing, can you supply a screenshot of the icon?
Sorry for the inconvenience this may cause.
guy_c
Ended up finding it was by the application 'screen off' and lock.
Thanks for your help
Jake-SonyXperia
Champion
Thats good news, I hope all goes well for the future. Slightly_smiling_Face
guy_c
Tanks:)
Anytime Slightly_smiling_Face
