stamina mode not working after root
pchetan2
Hey guys, I have rooted using doomlord's easy rooting toolkit and is on .284 firmware . I have also installed cwm recovery, though did not unlock bootloader..stamina mode is not working now .I tried resetting the eco controller in apps ,it did not work ....Pls help me guys ,how can i solve this problem.I dont want any third party battersaver apps .............
thank you
perhaps you should repair your phone and try again
6 REPLIES 6
are you certain you did NOT unlocked the bootloader?
also stay away from battery apps, taskillers, taskmanagers, antivirus, ram apps and booster apps
http://www.engadget.com/2012/06/18/android-wakelock-api-bugs/
Android apps that use power control APIs are often 'battery killers,' oh the irony
pchetan2
I am sure ,i did not unlock bootloader
pchetan2
god!!!!!!!! i cant do it ,i have my favorite apps,favorite flashed zips via cwm   Slightly_frowning_Face
well you have 2 options 1 leave it as it is or 2 start all over
are you aware how the STAMINA mode work? btw how do you know it doesn't work?
