I have just bought a Sony SP. On my previous Sony phone I could Blootooth or use my computer to send my ringtones to the computer or another phone. When I open "internal" storage on my computer, I cannot find the ringtone folder so that I can copy my stored ringtones to it. I is similar with sounds, there is no option to use a sound as a notification or ringrone.
Jack UK
You can select a song as ringtone, you need to root your phone to be able to access the certain files on your phone.
You can create ringtones with apps such as ringdroid
