Ive buyed xperia t3 from a store shop but my phone got a some demo mode like TV, how do i turn it off ?
You turn it off by putting in *#*#sellmore#*#* using the dial pad.
In the future,please use the search button as this has been asked so many times:
/t5/Xperia-Z1-Compact/how-to-disable-demo-mode/m-p/787655#M8486
nvm found it, thanks
You put in the numbers which holds the letters. For example the button for number 5 is used for letters J,K,L. So SELLMORE = 73556673.
Great!
