my phone is not starting completely only it shows sony logo and then again shuts downd and this process is repeated continuously what should i do
Try Update Service, you need not switch on phone for this tool.
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
Hi, try repairing phone software with PC Companion or Update Service. This process will erase phone data completely.
http://www.sonymobile.com/gb/tools/pc-companion/
are u sure this will solve my problem
If it is a software issue, repairing phone software will resolve the problem.
my phone is rooted one
No concern, just try repairing phone software. Good luck!
its not working with pc companion not detectable
thanks for your support i am checking sus then i will contact you
You are welcome! Standing by. :smileysmileywink:
