Sony Xperia S battery?
I have read the battery is very bad so i think can i replace to example a better battery with a longer battery life???
subben2003
mine easaly holds 24 h.
The phone is the best smartphone i had
10 REPLIES 10
slimshaddy
Hero
have you purchased your phone , are you having some problems with the battery..??
xperia s battery's non removable so you cannot change the battery..
i saw some video in which a guy removed but dont know if everyone can do this..
i have not buy it but i have read it onnly can used i 8-10 hours
subben2003
en dansker nice
dustie
We are actually a few danes here Slightly_smiling_Face but yeah, I can easily squeeze out two days on my phone, if I don't use it alot.. I just have to disable 3G.. that uses up huge amounts of battery (i haven''t tested it with 3G on after i got .73)
I bought this phone Xperia S 4 days agao, I like the phone, the apps, the quality of pictures and video, except for the battery. It should hold for at LEAST a full day! The Samsung Note last a full day!
If the battery is not working properly, what is the point of having such a phone as the Xperia S??
I am very very disappointed in the phone and Sony, because the phone's battery should not be fully discharged after a mere 6 hours and then I did not even use to watch a movie or listen to music!!!!
I tested it twice now on days I'd been away from home all day.....of course I took my charger with me.
1 day I watched one video of 52 minutes and did not listen to the music on the device, day 2 I only listend music on the device for 30 minutes.
The first day I was away I had a movie shoot, I was watching a video of 52 minutes. I took my phone from the charger in the morning and saw that it was not even on 100% capacity.......around 3pm my battery was drained and I had only 25% left!!!! What the helll!!!!!!! :S
This day I charged my phone 2times! One somewhere on the movie set untill it was fully charged again (green light showing ) and I had to do it again when I got home...... :S
Oh yeah I turned off the Bravia Engine and wifi ( which should not have to, even on my blackberry 9700 everything is on and the battery last a full day!!)
The 2nd day (yesterday ) I only listened to music while I was outside for 30 minutes in total. In the morning when I took the device from the charger it was on 100%....surprised, BUT around 3pm again my phone's battery was almost out of juice. When I came home I had to charge the phone again. Took it off the charger again at 6.30pm for  a performance. I got home at 11pm....and what did I see.....battery almost died AGAIN!!!! This day I also had my Bravia Engine on because I think this should not matter. I took a few pictures on 12megapixels, stopped listening to music via the Xperia when I had to go away for the second time that day.
Nowhere on the web I read  that this problem will fix it self after a while or that Sony will do something about it. Today will be another test day for me......and most likely I will receive the same result. I can still change the phone but when I do....I will go for the Samsung Note. A good friend of mine has that one and has EVERYTHING running, plays games on it, watches movies, youtube, all his email comes in, takes pictures and listens music on it. He has no problems with that device.......
I'm a Sony fan...this just saddens me because this should be the most powerfull smartphone at this moment. If I do have to keep a Sony Xperia S....and the problem stays....I will write a complaint letter to Sony because this is UNEXEPTABLE!!!!
i,ve installed juice defender, i turn off the connectivity when you lock the screen, i'm using the free version and works very well.
Bye Antonio
DanielAmara
I HAVE A PROBLEM WITH MY SONY XPERIA S .PLease help !!!
The problem is with the battery indicator .
First thing the battery menu show a statistic of battery usage and how much time is left till 0% ...
the problem is that when the battery shows 1 % this statistic show unrealistic time like 22 h left on battery ?!?!
Sometimes my battery indicator shows 100% percent and after i unplug the phone from the recharger fot one minute
it drops to 0% anf turn off. In other cases my phone does not charge to 100% instead it stays on 1% and then i can use my phone for a couple of hours
with 1% battery ?!?! My sony xperia s is charging differrently - sometimes the battery goes for one minute to 100% (which obviously is not true)
and other times its stays at 1% (but then i have small amount of charge for couple of hours) . I tried repairing it with sony repair tool ... but the only thing it does is clean reinstall and the problem is still there. Please sony give me an advice or try to help me . I love sony as a brand ,and im very happy with my xperia s till now. The phone does not have a single scrath . Its in perfect condition please help !
slimshaddy
Hero
well the stats shows that how much time you used your phone without charging Slightly_smiling_Face
also i'd suggest you to take your phone to the nearest service center to get it checked. take the phone's bill with you.
