Sony Xperia Neo not turning on
Hi. I wanted to updated my phone to ICS. I followed all the instruction in the thread http://talk.sonymobile.com/thread/35239 .. WHile flashing it said... Flashing loader.. then an Error occucred and it aborted flashing. Now my Mobile wont turn on at all. Even when i connect to charger the warning light also doesn`t show a red colour for charging(like it used to). Now even PC is not detecting the mobile and not even SUS. Please tell me what to do.....
25 REPLIES 25
OK I now know whats wrong with my mobile. I have damaged my Bootloader... Please can anyone tell me how to fix the bootloaders ?
Thank you very much Uliwooly..... I finally fixed my mobile.... I also understand what the problem was... I had damaged the bootloader + battery was also empty. When I started to flash my mobile with flash utility it started flahsing but since mobile was low on battery ...it used to shutdown in process .... On the other hand ... what i was seeing on screen was that flash utility used to get stuck IF theat different places.... so i kept it flashing again and again and one time i completed the flash and WALAAAH.... mobile was perfectly ok ... So when  red light blinks three times that means that battery is dead... EVEN if you have a corrupted leader....
A cell will be bricked if it doesn't respond at all to anything even the led light will stop working
Anytime
unrelated topic, if you have some time please check this thread
http://talk.sonymobile.com/thread/44888
Tahir
@Uliwooly. Thanks bro. U r a life saver. I slept at night and when i woke up my phone was not turning on and whenever i connected it to the PC it showed phone malfunctioned. The phone wasn't charging and whenever i tried to turn it on orange light blinked three times. I then following your advice here took the battery out held press the power button for 20sec then my phone was perfectly charging after 45 min i turned it on and it was volaaa.
Thanks broooo thanks alot i love my xperia and ur advice saved me. Thanks.
anytime Slightly_smiling_Face
hazwan
my neo keeps restarting.when i did turn it on... the warning light blinked green once and the mobile vibrated... then it keeps restarting.I pressed the power button again and no response.. but when i remove and reinserted the battery the same thing happened.. when i connect with with USB cable the green light stay on but systems doesn't detect device .i also did ur advice but it doesn't worked.
heidoooo
Hi Uliwooly!
     I did all the steps STILL I can't turn on my Neo L Slightly_frowning_Face Please help!!!
you have to take your phone to a Sony repair center or try different usb cables
heidoooo
i just bought this phone last dec 22 so its imposible that the usb cables is broke. Slightly_frowning_Face it just keep on blinking red light.. Slightly_frowning_Face help please
if you just bought this phone, you should return it/exchange it, at least thats what I would do
