In general, such a problem ... gps enabled and is not run applications that use it all right, but once you launch any application that tries to determine the location of 30 seconds after the screen goes out and goes to the phone restarts ... anyone any ideas?
i mean "root" not "boot"
same problem here, i don't think sony will help with this, they want us just to buy a new phone jejeje, the rooting really works?
I rooted my Ion with DooMLoRD_Easy-Rooting-Toolkit_v18_perf-event-exploit.
I just modified the line with SUPL_PORT = 7275 in the file gps.conf by SUPL_PORT = 7276 with ES Explorateur (Play Store).
Since I done that more than a week ago the GPS work without any problem.
Thank you to those who found this solution.
Thanks a lot Mezozoy. I am having a doubt on sony is this bug done from there end suddenly to stop using this iON. Because this was one of the best phone sony having in that much low bugget.
i tried what you guys said but whem i try to save the gps.conf file it doen´t let me.
i´ve rooted the phone and i am using the ES explorer tool.
if anyone could help me i woul appreciate it
Hi, you have to check "root explorer" option in ES settings. It should work.
Hello
I also updated the Android version 4.1.2 got hooked when I want to use the phone's GPS service will automatically be restarted.
Please advise. Thanks.
@Mezozoy wrote:I have some problem.
The solution is change in file /etc/gps.conf line SUPL_HOST=supl.sonyericsson.com with SUPL_HOST=supl.google.com.
You need root for this.
THANKS A TON IT WORKED
On my phone I had to change both.
1- google.com
2- 7276
now is working
so far...
