Sony Ericsson Synchronisation
Can I restore the last last syn in SE syn website?
suze
Leader
In the bottom left of the sync site online there is a little dustbin with 'I need to restore removed objects' is this what you need?  Have you wiped one or all your contacts by syncing? It looks like a tick box to select one/some/all to restore them to the sync.
2 REPLIES 2
suze
Leader
Thank a lots! I'm xo happy to restore because I lost all my contacts........
