I have activatet the encrypyion under secuity settings.
How do I remove the encryption setting and decrypt my data?
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
It's not possible to decrypt the data in the phone. To remove the encryption you need to perform a factory data reset which will delete all your data. You can do this from Settings -> Backup & reset.
