SD-card problems regarding Xperia SP
ApiO
I've bought a Xperia SP phone. When I bought it I got a 32 GB micro SD-card with it. My problem is that I can't reach the SD-card via my cellphone. Isn't the entire point of having a SD-card that the intarnal memory is too small to begin with? I have no problems removing files (photographs, music, documents, downloaded files) from the internal memory to the SD-card, the problem is reaching them through the phone (or moving them back). Could someone please help me?
Thank you.
Tags (2)
profile.country.RO.title
_alexdon_
Yes,the internal memory as well.You can use androzip,astro file manager,es file explorer.
alexdon
7 REPLIES 7
_alexdon_
Can you use a file explorer or the inbuilt option in settings-storage?
alexdon
ApiO
What opiton? When I go into settings > storage, then the only thing I see is the SD-cards available and occupied storage. I can't see what's on it, not even which sort of files that lies on it.
P.S. I'm not sure what you mean by 'a file explorer'.
Thank you.
_alexdon_
With the inbuilt option,you can only move to SD media.By file explorer I mean an app from google play you can use to see your memory organized.
alexdon
ApiO
Okay, so I found some apps. Is that the only way that I am going to reach my SD-card?
_alexdon_
alexdon
jazzy_xperia
you can only move photos and videos and others multimedia files but not apps...
Harpoman61
Yeah I know what you mean. I bought a game and it was too large for the phone. Tried to put it onto the SD card and couldn't. Their software was good but  now is rubbish. It lets it down. Also they are a game producer so what goes on SONY!!
