Screen Capture gone
Screen Capture gone
Anyone else noticed that screen capture function was removed after ICS update or is it just me
it's just you
8 REPLIES 8
it's just you
just press at the same time the power button and volume down
would you mind letting me know how to getting it to work again
before the update i just held in the on button, but when i do it now i only get shut off phone, air plane mode and profiles
thanks
Anytime
alirezahejrati
thanks it is working Slightly_smiling_Face
anytime
Richman10
've tried this until my fingers got red. It doens't work. It is silly to change something that works for a 'novel' system that doesn't.
