Right side of screen not functioning.
Hello, I bought my ray a couple of weeks ago. It seems to have an intermittent fault where the right side of the screen goes dead or top if the phone is in landscape. This means I am unable to delete in texts and push icons to the right in the home screens etc. It seems to rectify itself for an hour or so then goes wrong again. I have emailed Sony and they recommended doing a software repair through the pc centre. Other than deleting all my apps etc this did nothing. Can anyone suggest a solution for this. I was wondering if it was a calibration issue and if there was a way to adjust the calibration?!
Nabeel
Master
thats it,,, problem verified
this is not a software problem, its a hardware problem
rush to your sony service center, only they can help you with this..
5 REPLIES 5
Nabeel
Master
seems to be a hardware issue only!!
whats your build number ??
dial *#*#7378423#*#* in dialer > service tests > touch screen> move your finger all over the screen to test it
Hi, the build number is 4.0.2.A.0.62.
I did the test and the rest of the screen is fine but there is a strip about 3/4 of a cm wide that doesn't register any touch.
Nabeel
Master
That is what I was afraid of!!! Thank you for your help I will contact Sony customer services this morning and find out where to take it for repair!!
marierenaud
It seems that I have the same issue.
Suddenly, 2 hours ago, my touchscreen have stopped, at least the right half side
I can't use my phone, as it's locked and my scheme use both left and right side, I can't answer calls, I can't do anything in fact...
I've tried to shut down and restart but nothing has changed.
I have the software bridge for Mac but I don't know what I could do more...
What could I do? I can't test #.... as I don't have the keypad
I have replaced front and back screens 3 weeks ago, after the front screen broke, (considering the back screenbroke without any reason a few months ago, but I didn't change it as it was just "aesthetical"), it worked normally until today... Maybe has it something to do with the screen replacement?
I really appreciate if you can help me!
Marie
