I have a sony xperia s and i was wondering whether you are able to record a phone call. If you you i would really appreciate you telling me how due to this function being really important. I dont mean anything special, normally its just a button on the screen however i dont see one on the sony xperia s.
Thanks so much guys...
The XS does not have this feature built in however I use this app https://play.google.com/store/apps/details?id=com.appstar.callrecorder&feature=search_result#?t=W251...
It auto records phonecalls and if you want to delete it afterwards simply open the app and choose the recording then select delete
For me and my business I get phone calls offering me deals which I accept etc but fail to get the deal I agreed to over the phone - When told I wasn't told this as they checked the phone recordings I can then post them a copy of this call and they soon fullfill their deal plus extra as a goodwill gesture - So from experience I like this app and do use it
Thanks... I have the Sony Xperia S, What app exactly do I have to go to?
Sorry about this and thanks for the tips
Thanks! Works a dream and really needed. Thanks again.
So on my phone bear in mind I'm still using GB so the look will be different from ICS
1st image shows the app in the app display window
2nd shows what recordings look like when you open the app and
3rd shows what options you have when you open a recording
Hope it helps
I've an xperia SP and i tried many call recorder apps from play store but no use, it will record upLink or downLink, simply i just want a call recorder which record from phone line, i really needed Please help me..?
https://play.google.com/store/apps/details?id=com.nll.acr&hl=en
Have you tried this one?I heard that it works ok,some friends of mine used it.
In some countries recording a phone conversation is forbidden. Sony adapts its models sold in those countries to that rule. It is a bit patronizing from Sony. It may be possible to switch the blockage off in Android, but I don't know how.
I want to record all phone calls
