Re: SONY XPERIA S LT26I USB REQUIRED TO MUCH POWER
victor5
My Xperia s battery drains so fast Wat can I do and also is there any way to update my Xperia s to 4.2
@vyrhus
http://support.sonymobile.com/global-en/xperias/software/
Android version: Android 4.1 (Jelly Bean)
Latest available software: 6.2.B.1.96
Release started: 2013-08-26
The last update was released almost 2 years ago, there won't be any further updates, your phone it's more than 3 years old, it'll be wise to reinstall the latest update, if that doesn't work then the issue could be a hardware issue, perhaps you need a new battery.
9 REPLIES 9
victor5
I installed it with pc on my z1compact but still the battery is still fast draining I need your help
victor5
Please how can I update my Xperia s stock on 4.1.2
@vyrhus
Have you perform a clear update/repair? which means everything will be deleted?
@vyrhus
victor5
Thanks very much I wil reinstall the update
victor5
But sorry to bother you again how can I go about reinstalling the update?
@vyrhus
It'll be wise for you to check the XDA forum as you could flash a Custom ROM
@vyrhus
you can repair your phone with PCC
PC Companion (PCC)
Bridge (for Mac)
