problem on wifi with xperia go
LAbnene
i have a problem with the wifi of my xperia go, everytime my phone will be shut down and my wifi is turned on and connected to a server,i can't connect it after i turn it on.. it counts almost 7 days before it connects again. it always happen since i bought my phone. thankyou for the solution.
gwhispererz
Champion
Keep us updated. Fingers crossed! Slightly_smiling_Face
Don't forget to mark correct answer as Accepted Solution.
If you find the post helpful, press Kudos.
7 REPLIES 7
gwhispererz
Champion
Hi, are you experiencing this issue with all Wi-Fi network or just a specific one?
LAbnene
i experienced this issue with any of those wi-fi network that i was connected, before my phone shuts down.
gwhispererz
Champion
Did you try to software repair phone or at least a factory reset?
LAbnene
not yet..i will try it right away..thank you
gwhispererz
Champion
LAbnene
thankyou for the solution.. my wifi is now working.. but i have a problem now after i repair my phone.. its been hard to touch.. i mean some of the keys (specially in typing) is not working., most of the letters wont function normally.. what can you advice? thankyou
gwhispererz
Champion
That shouldn't be the case after software repair. See if factory reset helps.
