Problem in updating with a Xperia tipo dual
CecileCharbon
Hello!
I have an Xperia tipo dual since a year and a half. I only have 19 apps on it. When I want to update apps I already have, I am told that there is not enough storage space. Three months ago, I reinitialized it - I read on the users' guide that it would help. It did (I had to redo the password thing with the bank app though). Now, my phone informs me that new updates are available. I try to update the apps. Here it goes again! Not enough storage space! Are the apps getting bigger every time? I am losing my patience. What can I do? Thanks in advance for your answer.
Tags (2)
Indeed, apps will get heavier and more cpu ram demanding
