Hello Spartans,
I would like to know the prerequisite to activate Timescape for Facebook/Twitter in Xperia S mobile & also for activating 'Facebook Inside Xperia'.
I followed below steps and nothing seems to be working :-
Timescape for Facebook :-
1. Settings -> Accounts & Sync -> ON (made available for Facebook)
2. Opened 'Timescape' and clicked on 'Facebook' option, Facebook app screen opens and loads and comes back to 'Timescape' page with 'Connect to Facebook' option.
How should i proceed ? Which setting am i missing?
Facebook Inside Xperia :-
2. Settings -> Xperia -> Facebook Inside Xperia is checked.
Again facebook screen opens, loads. Comes back to same 'Facebook Inside Xperia' screen & the option is unchecked automatically.
Suggest me some valid Explanation or method, please for god sake don't ask me to reinstall using PC companion, this sunday only i had got an update for new version and my android is updated successfully.
After reinstalling phone s/w i tried timescape for facebook, it was displaying 'could not update from facebook' error. Then i installed the apk shared by you, its working seemlessly now..
Thanks alot
download this file and install the APKs in the phone .
http://www.mediafire.com/?fl4p8f4vpx0jp16
i hope i helped you
Hello micheal96,
I already did that, but its not working for me. thats the reason i created a new discussion to have guidance from Moderator.... Even 'Facebook Inside Xperia' doesn't work...
Clear the app cache from configuration>apps>currently running
Reinstall the EventStreamFacebookPlugin from the apk posted before, that should work.
its not working..........
1 .I did 'Clear Data' for Facebook.
2. INstalled the plugin from medaifire link.
3. Still shows the same screen (Connect to facebook)..
sorry
i can't help anymore:smileysad:, it worked with all members
maybe you did something wrong , try to do everything again maybe it'll work
can you give me a screenshot of the step 3 (connect to facebook)?
The following screenshot shows the related error that can be fixed with the solution posted by micheal96
Post your screenshot here, if you can't take the screenshot just press PowerButton + Volume - together.
Since its working to everyone, am reinstalling my OS (NO other option).. if the issue still exist after that will post the screenshot..
Keep you posted..
