hi π
is there a Xperia theme in white background instead of all the pre installed black themes coz I really have a trouble with these black themes I can't see the words
I was a user for I phone just for this reason because its menu in white although its A very boring and stubed Mobile
I am really happy with this system and Xperia S but this problem really confusing me
I hope in next update you put some white themes in it,,
put is there a way I can apply a white theme?? Until you put more themes options
I searched over the internet and the store but all the available is not an original one They changing the all system and mobile and menu . Helppppppp me plz π
Jelly Bean update has white background for the phone app and messaging app.
you can switch to white theme by installing golauncher themes from the market
I hate it too. Every app has another theme!!! Settings black, phonebook white, walkman black!
It's as step backward!
can I change the white theme contacts and messaging to black? because the white skin very bright for eyes.
thanks
as you can read above, no you can not, you can use a different messaging app from the playstore
