I have a question.
When I take a picture with some movement in it it look likes the camera will 2 times expsure the image.
Anyone an idea or solution how to prevent that?
Thanks, Damiaan
turn off HDR in normal mode. if you are using superior auto mode, try change to normal mode or scene mode and then turn off HDR mode.
