How do i stop my phone vibrating when i receive a notification, even though I have turned off vibrate?
my bad
go to settings -> sound -> vibrate -> never
or
open the messaging app -> press MENU -> settings -> notification vibration
the notification shouldn't vibrate for long, you can always press the volume keys
You misunderstood me, the phone does not vibrate continuously it vibrates just once, but the problem is i turned off vibrate setting and it still vibrates when i get a notification.
Thanks, message app settings sorted it out....
Anytime
Hi..
I am using Xperia L mobile... when i am receiving bill my mobile s getting vibrate...how to stop it??
