Phone constantly overheats, shutting down constantly, sim card removed?
The drain on the battery lately is shocking, doesn't even last for an hour, had it for over a year, no bother, but this is doing my head in.
Any help greatly received.
I had the same problem with Xperia T, it started crashing with the camera, then randomly shut down while I was using other aps, also phone overheating/battery draining issues and I could only use it while plugged in, last week it started rebooting itself for 3hours non stop as I was unable to turn it off, now I cant even turn it on anymore. My cell phone company said there was a recall on this model but its probably a way of shifting the problem from them. Sony should issue a recall soon if they want to stay in business.. no one is going to buy their crappy phones.
