Hello friends,
Today morning i read on a website that there is a new ICS firmware update for LWW as well the rest Xperia 2011 series 4.1.B.0.587. I want to know what is the update for ? Does it fix the rest bugs left in ICS ? Thanks...
Upto my knowledge updates will be available soon for Live With Walkman WT19a don't have any idea that will sony provide update for WT19i or not.
Source : Wt19i : http://ptcrb.com/vendor/complete/view_complete_request_guest.cfm?modelid=19869
Wt19a :http://ptcrb.com/vendor/complete/view_complete_request_guest.cfm?modelid=19868
You can check it.
thanks after viewing the link its clear that . . . . i should wait a bit
if i unlock bootloader in LWW, then will i be able to get these future updates OTA or PC Companion?? pls reply
i dont think so . . . but surely there are other ways through which u can update your phone with future releases
i want to use pen drive as lww supports usb on the go feature. mouse and keyboard is working properly except any flash drive. Could you suggest me what to do?? I'm lil bit confused...
Hi all! Please, answer me, why in 4.0.4 I don't much connect my LWW to PC through WiFi for file sharing? In 2.3.4 all been ok. Some menus disapear in new version (Settings---Sony Ericsson---Connections). Thanks. Happy New year if your celebrate it!
I had tried it on my Xperia mini. Yes, it was better than previously ICS. I would say, I still prefer Gingerbread (2.3.4), faster that ICS.
@Dexter i know all this information, but u still can get in adobe.com flash player for ICS, i used it many times, just try to visit here: http://helpx.adobe.com/flash-player/kb/archived-flash-player-versions.html (it always updateting)
