Neo V ICS update, battery drops from 21% to 1%
dres85
Hello,
I have a Xperia Neo V and I recently updated it to latest version (ICS European) with PC Companion.
Since the update, the battery is being inaccurate, it suddenty drops from 21% to 1%.
Can someone please help me?
What can I do to fix it?
Thanks,
4 REPLIES 4
dres85
It seems like the problem is solved. Now the battery stay "alive" until 1%.
Thx Winking_Face
winil
I have similar problem with my Xperia Neo V.
You said the problem is solved, but could not see the reply from Nabeel as to what needs to be done??
Can you please suggest
Nabeel
Master
