- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi and welcome to the community! Since you're new please be sure that you have checked out our Discussion guidelines.
I suggest that you remove the battery and insert it again. Without powering on the phone, connect it to the charger via wall socket and let it charge for 1-2 hours. If the battery is completely flat, it can take a longer time before the phone indicates charging.
If there are no reaction after this, I would suggest that you try another charger and if possible another battery to exclude problems related to your accessories.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
buddy at the end what did u do to fix problem?
